Unexpected software 26.0
redsector
A strange thing happened today.
I did an software upgrade from 25.11 to 25.12 on one of my WLAN-networks.
And now some of the accesspoints are showing the software version 26.0 altough 26.0 wasn´t offered. Two of four accesspoints are on 25.12 and two are on 26.0.
BrandonS
6 Replies 6
Adam
Check through your old emails or firmware update logs.  Sometimes Meraki will push beta firmware to a portion of your devices.  But I noticed something similar to this with my MV cameras.  My MV12's have a different firmware than other models.
BrandonS
26 is a special release to enable some Umbrella features.  You are supposed to have to request it from support as I understand.  I would call support and ask them to fix it if you do not want it.
BrandonS
Here is the post about it: https://meraki.cisco.com/blog/2018/08/meraki-mr-umbrella-a-match-made-in-the-cloud/
I had to request access to 26.0 through Meraki Support. That firmware release allows integration through API's to an Umbrella (formerly OpenDNS) account. This means you can create policies and groups within Umbrella and populate them into the MR boxes.
The new "E" access points also use this firmware, even if the dashboard reports 25.x.
Correct, depending on which models of APs you have deployed, the newest models only run 26 firmware, and that may be reflected even though the network firmware version is 25.something.  Give Support a quick call to confirm, and as others mentioned definitely have them log a case if you do NOT fall into that situation with new APs and 26 did in fact get pushed unexpectedly (assuming you've also said "no" to trying beta firmware).  Post back to let us know what's up!
