Dear All,
I have recently created an ssid "wifi-guest" with splash page (PSK), when i use my iphone to connect wifi-guest and credential popup in seperate page rather than inserting psk password in the splash landing page, is that normal ?
Keith
Solved! Go to Solution.
Firstly, the configuration you want to do does not exist, the splash page will ask for another credential and password and not the PSK. and yes if you are using Click-through it is expected behavior (Users must view and acknowledge your splash page before being allowed on the network).
Did you configure psk at security or at splash page?
I Never seen the option to use a psk in a splash page.
There is no option for authenticating a PSK on the splash page itself.
You can use PSK for authentication and show a splash page afterwards.
If you want to authenticate on the splash page, you need to use either sponsored guest login or "sign on with..." and selecting an authentication provider.
yes i'm using the Click-through splash page, after entering the password and then acknowledge page appear and check the accept button to process to internet, so that is normal step ?
Yep, It is.
thanks all for your help
