Meraki Sensors Wireless
PQR
Is there anything similar to wireless sensors in Meraki?
Or how can the Aps sense the wireless service?
KarstenI
I understood it in a way that this functionality is based on the APs Scanning radio. But I also have not seen any detailed information. Eagerly waiting.
6 REPLIES 6
BlakeRichardson
I am not sure what you are asking. What are you trying to achieve exactly, what is the issue?
For example:
https://www.cisco.com/c/en/us/products/wireless/aironet-active-sensor/index.html
Is there something similar to wireless sensors in Meraki?
RaphaelL
Yes and no.
Something has been announced to Cisco Live and will be made available with MR30++ firmware. Can't find any documentation to share with you
A meraki device? Or wil it be something like a generic thousandeyes probe
KarstenI
MerryAki
Hey, The MT Devices should use Bluetooth and connect to a MR nearby. Of course there are a lot of Bluetooth sensors on the market, but personally I would love to see 3rd party Integrations, such as: LoRa/LoRaWAN, Enocean/ZigBee or Z-Wave using USB Port on a MR.
