Hi Gabriel_Costa,
A warm welcome to Meraki Community 🙂
To summarize all great posts mentioned above 🙂
It depends on the AP model, in most cases the colors meaning are as follows -
https://documentation.meraki.com/MR/MR_Installation_Guides:
- Rainbow - AP is initializing/scanning - in other words trying to connect to Meraki Cloud
- Blinking Blue - AP is upgrading
- Green - AP in Gateway mode with no clients
- Blue - AP in Gateway mode with clients
- Blinking Orange - AP can't find uplink
Next best troubleshooting steps:
STEP 1 - Connect a PC to a known working switchport with a brand new cable with Wireshark installed:
- Start the Wireshark packet capture on the PC
- Is the switchport LED color light green?
- Did the PC receive an IP address successfully?
- Can the PC ping it's own Gateway?
- Can the PC ping 8.8.8.8 and browse to the Internet?
If the answers are "Yes" on all questions above, continue with the next steps.
If any of the answers is "No", please check the switchport configurations (trunk/access mode, VLANs etc.), or why the PC can't receive an IP address or ping 8.8.8.8 upstream etc.
STEP 2 - Please, connect to the Device Local Status Page - https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
1) What does the "Connection" tab shows under the rows:
- Ethernet - It should show "The access point is directly connected to a local network. IP address XXX.XXX.XXX.XXX"
- Internet -  It should show "The access point is connected to the Internet"
- Cisco Meraki Cloud - It should show "The access point is successfully connected to the Cisco Meraki cloud.
2) Download the Support Data Bundle (SDB) and send it if necessary
3) Perform a factory reset on the AP by inserting a paper clip for at least 35 seconds.
4) If the issue continue, please create a case with Meraki Support Team for further investigation with the above information ^
Please, find the documentation of how to download the Support Bundle File- https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Out-of-Band_Log_Fe...
If you have any questions, please don't hesitate to contact us.
