stack MS225 series PoE with Non PoE switches
Htaha
Can i stack MS225 24/48 PoE with Non PoE switches knowing that all of them are MS225 series, is there any issues?
Thanks.
AjitKumar
Hi @Htaha
I understand this should be absolutely fine.
Whether POE / Non-POE / 24 / 48 Port. I understand we can stack them together with "No issues".
You may check the following Url for more information on Stack Compatibility & configuration.
https://documentation.meraki.com/MS/Stacking/Switch_Stacks
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
AjitKumar
Hi @Htaha
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Htaha
Hi AjitKumar,
thank you for your reply.
@Htahayou can stack all variants of MS225 switches with each other and also with MS210 switches.  We have stacks of MS225 48 port switches mixed with MS210 24 port and MS210 48 port ones (all with PoE but that doesn't matter).  They work absolutely fine together.
DarrenOC
You won’t have any issues with this setup.  We do this all the time
