portfast
pavan_1379
portfast
How do I enable portfast in Meraki Switches? Please let me know
BrechtSchamp
I believe if you set it to "access" mode in the port settings it automatically enables portfast.
Automatic edge port
MS switches will automatically place all ACCESS type interfaces into EDGE mode. This will cause for the interface to immediately transition the port into STP forwarding mode upon linkup. The port still participates in STP. So if the port is to be a part of the loop, the port eventually transitions into STP blocking mode.
Source:
https://documentation.meraki.com/MS/Deployment_Guides/Advanced_MS_Setup_Guide
2 Replies 2
BrechtSchamp
Automatic edge port
Source:
@BrechtSchamp  is correct.  Meraki switches running the more modern version of spanning tree known as RSTP, so this isn't really a "thing" anymore.
