route map on meraki ms
TheMightyGaur
Moving to Meraki to replace old core switches.  I have a subnet that is route mapped to a secondary firewall as opposed to all the rest of the traffic traversing the switch (which uses the default route).  I have the SVIs setup on the meraki and the static and default routes I need for everything else.  It says that I cannot add a specific route for this subnet as it is already being routed. There is a svi for this subnet on this switch. Also, how do i see the route table on this device (MS 425)?  Thanks in advance.
Using route map for pbr?
Meraki MS doesn't support  Policy based routing.
Have you checked this?
MS Layer 3 Switching and Routing - Cisco Meraki Documentation
TheMightyGaur
so my only hope is to move this off to another layer 3 device that can handle pbr?
Brash
That's correct
