cable test - pair 3 and pair 4 showing short
teja
Hi fellow users of meraki ,
we  have  a  below connection on port 12 and it is having too many tx discards. Tried  cycle port and  still seeing below output  on cable  test . what could be the reason ?
Port 12: Connected to Kiwi DoorPad
Troubleshooting
Cable test
Testing the cable attached to port 12
Port Link Length Status Pair 1 Pair 2 Pair 3 Pair 4
12down44.25 mOKokokshortshort
5 Replies 5
Brash
Bad cabling.
For a short, probably poorly terminated at the patch ports but could also just be a bad patch cable.
Start replacing cables or cable testing the runs to confirm
Is something still connected?  It could be a faulty cable or device, or if the port connects at 100Mb or less then you can ignore it as only two pairs are used for data.
DarrenOC
As mentioned above - dodgy cabling. First try replacing the patching fly leads.
amabt
Definately doggy cables and or not fully pushed in.
BTW that length (where fault) is not to be trusted in my experience.
@amabt the length is the cable length, not the distance to the fault (if they are not the same).  I've found it to be good +-10% over the years.
