Microsoft NPS + Microsoft NPS for MAC-Based RADIUS
rabusiak
Hi Guys,
Have any of you successfully setup MAC authentication bypass policy with NPS?
I'm following this document: Configuring Microsoft NPS for MAC-Based RADIUS - MS Switches - Cisco Meraki
All is set according to documentation but port with this policy is not forwarding traffic.
NPS logs are catchings my device request but it says: access denied because no matching network policy was found
rabusiak
Thank you all for suggestions. I went for the 10th time through entire configuration and all was set correctly... except that I put test user in a wrong AD group 😛
This is why it's requests didn't match any of configured network policies 😉
5 Replies 5
rabusiak
Funny thing - I have also other Network policy which has NAS Port Type set to Wireless and is used for WIFI AD auth. If I remove NAS Port Type from it I have a match but then authentication method is not supported (unencrypted) and have access denied also:
Maybe it will help you.
https://www.youtube.com/watch?v=Iput9nLnldA
If the authentication request is coming in using PAP, then you need to add that as an allowed method in your NPS policy.
Is your Connection Request Policy ok?
rabusiak
