Which SFP is correct ?
TommyF
Two switches CP-MS250 and MS-130.
We have two options for fiber, prefer the yellow SM 1/125um fiber.
The other fiber is Aqua MM OM3 fiber.
The problem is we have tried several SFP's to bring up the link with no luck.
This is a 10GB link. Can someone suggest the correct 10GB SFP's for both color fibers please.
9 Replies 9
Mloraditch
MA-SFP-10GB-SR will work for OM3
MA-SFP-10GB-LR will work for SM
However to be clear you have an MS130 or and MS130-X? The regular MS130 only does 1GB.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu... You can view the whole chart here.
TommyF
Yes it is the 10G version
For your 10GB link, you'll need specific SFP modules for each type of fiber:
Yellow SM 1/125um Fiber Single Mode use a 10GBase-LR SFP+ transceiver.
Aqua MM OM3 Fiber Multimode use a 10GBase-SR SFP+ transceiver.
TommyF
The one switch is a MS250-48FP
The second switch is MS250-48FP
These should support 10GB in the SFP ports correct?
Yes, this is correct
Refer the documentation:  https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu...
DarrenOC
Hi @TommyF , have you tried reversing one of the heads on the fibre fly lead?
DarrenOC
Like this:
https://m.youtube.com/watch?v=OKtF97VT8ts
TommyF
We have it working thanks for all the help.
