- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
C9300-M port-channel suspended due to storm control native IOS-XE *workaround provided*
HI all,
I'm just installing a few switches at a customer.
The deployment is a stack of 2 C9300-24P-M with C9300-NM-8X in the main rack for collapsed core and access at the offices with a few MS130-48P switches scattered around the facility.
When I wanted to aggregate the two fiber uplinks between each MS130 and the C9300 stack I first aggregated them on the access switches before doing it on the C9300's.
When I ultimately enabled them on the C9300 the links went down.
Checking the logs on the dashboard terminal I found these nice entries:
%SPANTREE-6-PORT_STATE: Port Te2/1/1 instance 0 moving from forwarding to disabled
%ETC-5-CANNOT_BUNDLE2: Te2/1/1 is not compatible with Po1 and will be suspended (Broadcast suppression: Level of Te2/1/1 is not configured. Level of Po1 is 1.00%, 1.00%.)
%SPANTREE-6-PORT_STATE: Port Te2/1/2 instance 0 moving from forwarding to disabled
%ETC-5-CANNOT_BUNDLE2: Te2/1/2 is not compatible with Po2 and will be suspended (Broadcast suppression: Level of Te2/1/2 is not configured. Level of Po2 is 1.00%, 1.00%.)
%SPANTREE-6-PORT_STATE: Port Te2/1/3 instance 0 moving from forwarding to disabled
%ETC-5-CANNOT_BUNDLE2: Te2/1/3 is not compatible with Po3 and will be suspended (Broadcast suppression: Level of Te2/1/3 is not configured. Level of Po3 is 1.00%, 1.00%.)
This is strange since the running config on the individual interfaces already had following config
storm-control broadcast level 1.00
storm-control unknown-unicast level 1.00
One of the first things I usually do is limit the BUM traffic by configuring:
So when unbundling those channels the ports came back up as one would expect.
I then disabled storm control first, created the aggregates then and was able to re-enable storm control after the channels were made succesfully.
So for people in similar situations:
- Do the storm control feature in the final steps after the topology is up and running.
- Labels:
Interfaces
Layer 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This might not be related, but note this fix in 17.2.1 for MS.
Also note after doing this upgrade you have to DELETE and re-create the existing LAG configurations for the fix to be applied.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I considered that but in this case it was the first and only link that was being suspended.
And the log message seems to indicate that it is a bug having to do with the creation of the new Po interface.
