VLAN assignment after successful Cisco ISE authentication
RobHuijser
We have a lot of SER rooms (more then 30) in our office location, each location has assigned a user vlan /23
After authenticated a device/user, via Cisco ISE, the user must be assigned to the specific vlan on the connected switch.
Cisco is using [show] vlan group command to select the vlan for that switch, but how is this assigned with Cisco Meraki?
/Rob
BrechtSchamp
RobHuijser
Thanks, but no this is not what I am looking for.
All switches has the same configuration, but users are assigned in different VLANs after authenticated by ISE. The designated VLAN is switch specific.
BrechtSchamp
Could you not configure the SSID to simply use the "native" VLAN (aka bridge but don't specify the VLAN).  Users will then be automatically placed in the local VLAN on that switch - that the AP is in.
