Hi, if we using vlan 2 for switch management, do we need to change switch setting management vlan from 1 to 2 as weel? please advise, thanks in advance.
Solved! Go to Solution.
If your referencing this setting under 'Switch>Switch Settings'
Then I would imagine yes you would want to change it to '2' since that is what you want to use as the management VLAN for your switches.
In addition, here is the info from Meraki on the subject, from this link:
https://documentation.meraki.com/MS/Other_Topics/Switch_Settings
By default, the switch will try to contact Meraki Dashboard on the untagged (native) VLAN. Alternately, you can specify the management VLAN under Configure > Switch settings. This allows the switch to reach the internet via a trunk port.
If you change the management VLAN and the switch can no longer obtain a DHCP lease or reach Meraki Dashboard, the switch will revert to its previous management VLAN configuration.
If your network does not allow the native VLAN or any of the default VLANs to DHCP or connect to the internet, you will need to manually assign a management VLAN. To do this, place the switch on a network running DHCP, then from dashboard navigate to Monitor >> Switches and select the target switch. From the details page, choose "Set IP Address" and save your changes.
As @NolanHerring says - yes.
I tend to do it under "Switch->Switch Settings", which lets you configure it for every switch in the network in one go.
