Uplink SFP
Eddie01
Uplink SFP
I have a site that is migrating their present Catalyst 3750 switches to MS225 and 250, my question is. Can they reuse their present SFP's?
Eddie01
7 Replies 7
Inderdeep
Share the SFP models. Yes it will support for sure
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Eddie01
sorry that's the module
Eddie01
Inderdeep
@Eddie01 : yes GLC-SX-MMD is supported in Meraki. Go ahead
Eddie01
Thanks!!
Bruce
@Eddie01 just to caveat what @Inderdeep a has stated. Yes, those SFP modules should work. However, they are not actually supported. What this means is that if you log a support request and support believe the issue may be the SFP module they may refuse to assist until you have a supported SFP module in the switch (admittedly this is rare, but I have heard of it occurring). This is the same support that applies to any third party SFP, and yes I agree there is a certain craziness in Cisco SFPs not being officially supported in Meraki devices, but that’s what it is.
You can check the officially supported modules here https://tmgmatrix.cisco.com/ or here https://meraki.cisco.com/lib/pdf/meraki_datasheet_sfp.pdf and the support policy provided here, https://documentation.meraki.com/MS/Other_Topics/MS_Switch_SFP_and_SFP__Overview
Also note that if they are 3750's, they are probably 15 years old.  Do you really want to re-use 15-year-old IT kit in a new solution?
Bin them.
