Switchport, last time state changed
Dunky
This is so basic and available of every other brand I know, but where can I see the last time a port changed state?
Dunky
I am gonna mark this as solved even though the answer is its not available, all you can do is trawl through event logs to see if there is a record of the last state change.  I have filled in the "Give your feedback" on the dashboard and submitted a request but wont hold my breath.  I will report back that this simple request is not possible on Meraki switches!
5 Replies 5
Brash
You can find the info in either the switch's event log, or by sending to an external syslog
Dunky
No doubt I could get the information if I invested time and effort into finding it, however the information should be readily available.  I've been tasked with identifying ports not used for the last 120 days - I've done that on every brand we have (Avaya, Extreme, Nortel, HP, Aruba) with the exception of Meraki where the information does not seem to be readily available.
you can find port status in the event log.
Or use the api for event log https://developer.cisco.com/meraki/api-latest/#!get-network-events
Dunky
If the last port state change was say 300days ago that could take hours trawling through the event log to find it, thats if its there at all.
I have no idea how to use API's - is there a guide anywhere?
Dunky
