Switch clone vs Stacked switch replacement
JohnW63
I just read through this doc:
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
The subsection called Switch Replacement Walkthrough for Stacks mentioned actually screen shots and copy and paste.  That seems sort of old school if we have templates and profiles.  Then I read there is a switch clone button option. Other than a few things, that might need manual changes, wouldn't a clone with edits be better than using screen shots to change out a switch ?
I have yet to even touch a Meraki switch, so this is a less than novice question.
2 Replies 2
You shouldn't need to use anything else other than switch clone.  Used it many times without issue.
JohnW63
Then, why would Meraki put those steps in the Best Practices document ?
