Stacking and replacement
Henk1961
I want to replace a stack member with 48 ports by a stack member with 24 ports.
What will happen in that kind of a situation with the port configurations?
MS225-48FP ==> MS225-24P
Regards,
Henk
@Henk1961 I think you can only replace like for like, you will have to simply add the 24 port switch as a new switch and then remove the 48 port one.
2 Replies 2
DarrenOC
Hi @Henk1961 , @cmr is correct you can only clone and replace like for like switches.  It’s only a single switch so doing this manually will be simple and straightforward
