Rugged Switches
SilencerPG
Rugged Switches
Hi Community, is there any plan or road map to bring in a rugged switch model?  Preferably an 8-port with a DIN rail and DC power!
MerakiDave
Meraki Employee All-Star
@SilencerPG I and some of my peers have been making this product request to the MS PM team.  They are aware of the need, for example in the transportation space for bus, train, utility and first responder vehicles, etc.  Just because there isn't a ruggedized MS model today, don't let that stop you from contacting your Cisco Meraki rep, make them aware of the project and opportunity, so they can tag it against our internal feature request.  Those are the things that provide valuable input to the PM teams and can help set priorities.  In the meantime, I would sell you an IE1K switch https://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-1000-series-switches/...
10 Replies 10
NolanHerring
Doubtful since the ruggadized versions usually don't require Internet (cisco switches that is), so they can sit on a train or something. Cloud managed makes rugged setup tricky IMO
Nolan Herring | nolanwifi.com
TwitterLinkedIn
SilencerPG
100% agree Nolan, my usual solution set is to hang rugged devices off of a 4G router or other wireless connectivity.  I had a requirement last year that involved MVs connected wirelessly to a rugged 4G router but were then powered by a rugged PoE switch.  I would have loved to keep all of the equipment within a single vendor - makes management that much easier.
MerakiDave
HoneybadgerIT
There are a lot of uses for a ruggedized switch in the data center.  We place them in outside containers that house gen's, UPS, MV gear where it sometimes isn't conditioned.  Also rooftops and substation yards.  Sometimes it's a space issue as well.  We end up using the Cisco IE's but then lose all the visibility in the Meraki dashboard.
ChesterX
I have been looking for an outdoor switch.
Does Cisco offer a weatherproof box or cabinet for this product?
SilencerPG
Since I originally asked for this, the MG line has come out - the use case for my post is long gone however you now could connect a MG21E to a MV72 to provide connectivity to the Internet.
DC power for both devices and let the lecky sort out conduit/outdoor boxes for the LAN cable and power.
The problem then becomes one of security - there are ways to solve that though!
KarstenI
If ruggedized is tricky, then there should be a MS355-8FP/MS355-16FP (fanless) first! 🙂
@KarstenI I'd give you mode Kudos if I could, it is high time that a better 8 port switch came along and a 355 would get an A* from me 😎
KatAltamura
Thankfully, a Ruggedized version has indeed been released! https://meraki.cisco.com/product/switches/ms130r/
Ruggedized switches are not just for moving vehicles, in our case this fulfills our requirement for replacing an unmanaged switch on a light pole (in an enclosure of course) which feeds security cameras in our parking lot at one of our sites, as well as an outdoor pavilion at another site which feeds five security cameras and a wireless AP. These are all connected via fiber and have internet connectivity at all times.
KatAltamura
Just in case anyone coming here from Google reads this: Your wish has been granted! Meraki have recently released the MS130-R switch: https://meraki.cisco.com/product/switches/ms130r/
