Do you know how to roll back to stable firmware,when it's been more than 14 days since you applied beta FW?
I only get the below error.
SincerelyMikael Winther
Solved! Go to solution.
Can you select the network at firmware upgrades > all networks? Then press schedule upgrades and select the fw there.
Otherwise contact support
I´ll contact support, because that´s where i was at. 🙂
You wont be able to roll back, but if you go Organization/Firmware Upgrades, you can simply deploy the latest stable firmware.
