Phone Problem
athan1234
Phone Problem
Dear all:
A customer of mine is having trouble with Phone IP.
Works well, three days ago.
The clients inform me that just two of the phones I try to use function.
I'm noticing unusual occurrences that I can't explain.
On this switch on port 1 i see a router conection   i dont hace acces to this route
 Vlan voice 21 10.229.21.0/24
is the problem i meraki side or router client  side ?
It's why I'm telling you to review the router configuration. It's a basic tshoot. You need to check the port configuration on the router, the SVIs, etc.
Start with the basics.
11 Replies 11
Does the router have more than one SVI? Have you confirmed that the MAC addresses are the same for both routers discovered via CDP?
Also check you network topology:
https://documentation.meraki.com/MS/Monitoring_and_Reporting/Network_Topology
athan1234
Hi @alemabrahao
How is it feasible that vlans 99 and 21 have identical voz ranges?
Is it possible that this router has two vlan 99 configured with the same ip range as vlan 21?
Technically you shouldn't be able to configure the same subnet address for different VLANs, but it is a possibility, It would be good to access the Router to validate the settings.
athan1234
May be same getway ????
I suggest you ask your customer to access the router and check the configurations. There is nothing that you can do on Meraki's side.
athan1234
I asked him for the configuration, but he refuses to provide it to me since it would compromise internal security. Instead, he tells me what I need to know and offers to send it to me.
For you, the issue would be that this router has two vlans, 99 and 21, both of which share the same IP range
You cannot create different VLANs with the same subnet IP address, but you can configure a secondary IP address. But the best option is to review the router configuration. Perhaps the router could be receiving it via DHCP? well, I think he should trust you, but it's his choice.
athan1234
Thank you.
But this same hostname CDP is beyond my comprehension different mac address . Maybe they puted for mistake the same hostname to the routers
and  seems the vlan 1 is native with vlan voice getway . How it is possible ?
athan1234
ok , Tomorrow  I will  able to check it
