Certainly newer. I don't recall them a couple months ago.
Also, would be curious about a detailed if/then scenario for guest vlan vs failed auth vlan. With the access policy I did, failing auth dumped the port to guest vlan.
@Aaron_Wilson, there is a matrix in the link I posted (which I've now fixed). If you have a Guest VLAN and a Authentication Failed VLAN configured, then the matrix suggests the Guest user should've been placed in the Authentication Failed VLAN if they fail authentication. (If you only have a Guest VLAN configured, and are using Hybrid authentication then it ends up in the Guest VLAN).
Ok, that took a few reads to process. Almost seems like it would have been better to specify the vlan for the failed scenarios, rather than the configured/un configured options defining what "guest", etc, means.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b5cc1341be410","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b5cc1341be410_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b5cc1341be410_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b5cc1341be410_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_3b5cc12b38f47b","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
