NTP server
Asher
NTP server
How can i make NTP server on my meraki switch MS420 ?
No Meraki device can function as an NTP server.
14 Replies 14
not_Chuck
This no longer appears to be the case. I haven't configured anything special but when my phones request NTP from their default gateway, which is a Meraki MX, the MX responds as seen in the following capture.
Wow that is interesting!  I'll give that a try.
JohannesM
I'd open a case with Cisco Meraki to ask for a switch to disable it or to configure. You can't. It's in the DHCP Options. You have to overwrite it with your own DHCP NTP / Time Server Option.
We are establishing our own DHCP Server now, like we did with VPN and IPv6 Router...
Meraki was a mistake.
MarcelTempelman
Found this thread after PRTG discovered a SNTP service on a MX. I've tried to configure a MX as a NTP-server on a Catalyst switch..... and it works !
Uberseehandel
@Asher
Whilst you can't set up an actual NTP server, there are a couple of DHCP options which may allow you to achieve what you need -
Option 4 (Time Server)
This option is used to specify the time server available to the client. This is also related to the Time zone offset option.
Option 42 NTP servers
This option carries the NTP servers used on the network.
See - Setting Custom DHCP Options these work for both switches and security appliances.
The problem with using DHCP is almost nothing uses the NTP options.  I've found some founds that do, but that is about it.
Uberseehandel
So far I've only used the ones that do work. For example packet sizes.
BlakeRichardson
@Asher is there a real requirement for a local NTP server, can you not rely on an external NTP like time.google.com
Otherwise does your router not include an NTP option?
Asher
@BlakeRichardson
now I have added NTP in the Voice router.
I was in need for NTP to install CUCM.
Thanks,
King-of-Lag
retracted
SteveJones
@BlakeRichardson I just ran across this --- and stared at this response/inquiry in amazement.   I'm really hoping this was just a joke question, otherwise .........
KeithR
Technically you are not supposed to point to outside NTP servers as a matter of Security. It should stay within the Org.
https://www.nwtime.org/news/running-own-ntp-servers/
annmarie24
Just browsing
Upstream Firewall Rules for NTP
Meraki devices must be able to resolve pool.ntp.org and reach it via UDP port 123:
