Moving a Switch Stack to another Org
RouterJocki
I currently have 4 switches in a stack that need to be moved to another organization and need to make sure I have the steps correct.
First Do I delete the switch stack from the existing network?
Then I am assuming once the stack is deleted, I will remove the switches from that network then un-claim them from that organization.
Next step would be to claim these switches in the new organization and then put them in the new network.  Then I'm guessing I would add these switches to a new stack in the Network they were placed in?
The new organization has licensing to support these 4 switches.
Am I missing any steps that would be crucial to this move?
Yes, It's correct. Very simple to be honest.
https://documentation.meraki.com/General_Administration/Inventory_and_Devices/Using_the_Organization....
BlakeRichardson
Yip you have it spot on.
You will of course lose all configuration on the stack when you do this.  You could use the APIs to pull as much as possible from the old and push into the new.
