MS220-24p Replacement Fan
sandersfbc85
Where can I get a replacement fan for an MS220-24p switch? Got one that's making ugly noises after almost years of service.
You can't, you need to open a support case and ask them a RMA.
BlakeRichardson
Meraki gear isn't user serviceable with the exception of switches with removable PSU and fan modules which can be hot swapped out.
Make sure to do it quickly, the MS220-24p goes end of life on 29th July this year...
sandersfbc85
Thanks all, I opened a case and a new unit is on the way.
