How to align VLAN 10 to VLAN 22 ?
Will-Power
I was asked to check routing to align VLAN 10 to VLAN 22 in Meraki
What are the steps?
Leosambrana
what do you mean by align?
Routing on switches you can check at this KB
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Layer_3_Switching_and_Routing
Routing between VLANs on MX is done by default.
Leosambrana
Will-Power
How can I verify route from VLAN 10 to VLAN  20 in Meraki and verify traceroute to show response.
If both VLANs are created on the switch they are directly connected networks, no additional routes are needed. The client of each VLAN knows the routes to the networks through the default gateway.
