Mobile App cannot edit Port Profile?
Jujubee
I don't see a way to change the port profile in the Mobile app.  Is this expected behavior?  Using iPhone.
This seems crazy if I cannot change port profiles on mobile...
I use profiles to enable/disable ports and change VLANs etc...  Just easier to have a profile for unused ports then switch to used and voila...
TIA,
J
I don't know.
The mobile app is more for monitoring the network rather than making configuration changes.
DarrenOC
Never used it and most likely never will.  Just jump onto the dashboard with my phone.  One less APP to deal with.
BlakeRichardson
Not sure about profiles but I use the app often when I am on the go between comms cabinets and need to make minor changes i.e. name a port or change VLAN.
