New MS 18.1.3 Firmware out as RC - Few fixes
Mloraditch
Just a few fixes:
New feature highlights
  • Group Policy ACL on MS130 & MS150
  • Maximum MAC support in MAC Allowlists
  • 802.1x limited access mode with pre-auth GPACL
  • Local Status Page connectivity diagnostics enhancements
  • Layer 2 multicast live tool
  • Traffic Mirroring: RSPAN & VLAN Based SPAN
Fixed issues
General fixed issues
  • Fixed a bug that sometimes caused switches in stack configurations to fail to remove older entries from the MAC forwarding table
Ms150 fixed issues
  • Fixed a bug that sometimes caused MS150s to experience transmission errors and lose connectivity until they were rebooted
Ms425 fixed issues
  • Resolved an issue that caused clients authenticating via 802.1X with an access policy using hybrid authentication to not correctly log their RADIUS sessions
  • Fixed an issue that caused some switches in stack configurations to experience high CPU utilization in multicast scenarios that sometimes resulted in network instability
Known issues
General known issues
  • MS130 and MS150 switches may not properly display IPv6 RA packets in dashboard packet captures
  • MS130 and MS150 switches may incorrectly remove or update SGT tags when no policy or VLAN mapping is defined. Until a firmware fix is available, correct SGT tags can be preserved by defining a policy for the SGT group in Adaptive Policies, and binding the SGT group to a VLAN using VLAN profiles.
  • In rare circumstances switches may experience uplink instability when IPv6 link-local addresses are enabled. If this issue is encountered it can be resolved by enabling IPv6 RA Guard to block ICMPv6 neighbor discovery messages.
  • Some switches may encounter an error, "incompatible configuration for attributes: allowed_vlans" when attempting to aggregate ports regardless of allowed VLANs configured in Dashboard
Ms120 known issues
  • Switches may fail to provide PoE power to legacy access points (always present)
  • Cable tests may report incorrect cable lengths
Ms150 known issues
  • Wireless clients may lose connectivity when roaming between access points connected to different members of the same switch stack
Ms225 known issues
  • MS225 switches may infrequently stop forwarding client traffic until the switch is rebooted
Ms350x known issues
  • Switches may experience an unexpected reboot (present since MS 15)
Ms355 known issues
  • Switches in stack configuration may experience some ports failing to reconnect after a firmware upgrade
Ms410 known issues
  • Some MS410 switches may encounter alerts for fan failures that will eventually self-resolve
Ms425 known issues
  • In rare circumstances MS425 switches may encounter a software crash that results in a reboot
2 Replies 2
RaphaelL
Real diff between MS 18.1.3 and MS 18.1.2 :
4 fixes :
Ms150 fixed issues
Ms425 fixed issues
2 new issues :
  • Ms150 known issues
1 removed ( with no listed fix ) :
  • LACP links may take an extended time to come back up when the Active Member of a stack reboots
How are we still getting basic packet forwarding bugs at this point in time.
