Meraki Z4 acting as switch..
Zero_Faction
My Meraki Z4 is showing the switch option when I have no switches in my inventory or added? It's setup as combined. It's acting as if it is a switch.. anyone see this before?
michalc
Hi @Zero_Faction , welcome to the Meraki Community! 😊
You have most likely created your network as a combined network and you're seeing "Security SDWAN + Switching + Wireless … " which is expected and not a GUI bug as others mentioned. If you don't want to see "Switching + Wireless…" please split the network using the instructions from Splitting Combined Networks KB and than delete the unwanted networks
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
Mloraditch
Its likely just a gui bug from it being in a combined network. If you split the network from your overview you can delete the other networks and it should look normal after that.
Brash
As @Mloraditch said, it's likely a GUI bug.
Configuration or policies applied in the switch settings won't be pushed to the Z4
michalc
Zero_Faction
Thank you that was indeed it.
