- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
C9300 switches stack master election
Hi Meraki folks,
do you know how C9300 switches behaves in stack master election?
In standard Meraki switches manual election is not possible but how with C9300?
Do you have any URL to documentation? Thank You in advance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Running Meraki firmware the same is valid as for MS. Otherwise (running IOS-XE) it is the same process as for other catalyst switches.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
the document is for the 3750-x but the same is valid for the C9300 running IOS.
Master Switch Election
1. User priority - The network manager can select a switch to be master.
2. Hardware and software priority - This will default to the unit with the most extensive feature set. The Cisco Catalyst 3750 IP Services (IPS) image has the highest priority, followed by Cisco Catalyst 3750 switches with IP Base Software Image (IPB).
3. Default configuration - If a switch has preexisting configuration information, it will take precedence over switches that have not been configured.
4. Uptime - The switch that has been running the longest is selected.
5. MAC address - Each switch reports its MAC address to all its neighbors for comparison. The switch with the lowest MAC address is selected
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/c...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Understanding how the Active Stack Member is Elected
- If all stack members are powered up around the same time, the MS with the lowest MAC address will be elected the Active switch.
- If the stack members are not powered up around the same time, the MS with the highest uptime will be elected the Active switch, regardless of its MAC address.
- The Active switch will remain the Active switch until it's either rebooted or an event occurs that forces another Active switch election (such as stack ports being reconnected).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
In the non-Meraki managed stack I can set the switch priority so that the same switch is always the master and there is a pecking order for if that switch goes off line. Does the Meraki Managed flavor have that same capability?
Brent
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Unfortunately not 😕
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
thank you, what not sure
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you still have questions about the process?
