Hello Mike,
Re-configuring each switches' name in the dashboard UI will change the order in which they display under Switching > Monitor > Switch Stacks > select target stack > Overview, regardless of the physical setup.
The switches in the stack will display in ascending order by name on this page (or by mac address if names have not yet been configured).
If you manually rename the 3 stack members 1,2, 3 or A, B, C for example, they will show in the dashboard in ascending order like in the examples below:
This would require you to edit the name in the dashboard UI under each switch, as there is no option currently to edit each member's name while provisioning the stack.
Hope this helps to address you inquiry.
Best,
Feli
If you found this post helpful, please give it kudos. If this answer helped solve the issue, click "accept as solution" so that others can benefit from it.
