MS350 - 355 stacking issue
mariuszb
Hi
[None of my devices have been connected or plugged in yet if that will make a difference]
I am trying to set up a stack of 3 switches...
I have a stack of two MS350-48FP already created
When I try to add a switch to a stack as a member
MS355-48X2
I get This switch is a different model than other switches in the stack
what can I do in this case and what are my other options if anything
thanks
2 REPLIES 2
jdsilva
As the error message says, you cannot stack different models of switches with each other (the exception being 210/225).
The only thing you can do is connect it via Ethernet as a standalone switch.
https://documentation.meraki.com/MS/Stacking/Switch_Stacks#Stacking_Availability
Other options I can think oif is to return it and get 2 x MS355-24X2 and start a new higher perofrmance stack, or return it and get another switch the same as your existing stack.
I guess you could also get another MS355-48X2 and start a new higher performance stack.
