We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hi Folks;
Just quick question, can anyone tell me what POE spec a MS120-8FP supports? Is it;
802.3at or 802.3af ?
All I can find is that it will do 124 watts but nothing on what flavor of POE it is.
Solved! Go to solution.
@Bob_Jones it's POE+ so will be 802.3.at even though the data sheet doesn't mention it.
https://meraki.cisco.com/wp-content/uploads/2020/10/meraki_datasheet_ms120_compact.pdf
It supports both PoE and PoE+ and up to 124 watts.
https://documentation.meraki.com/MS/MS_Overview_and_Specifications/MS120_Overview_and_Specifications...
Thank you Blake, you nailed it for me !
Exactly the answer I was looking for.
