MS225 48 Port switch
Juanf574
good moning,
i just created a port aggragate with 4 ports. does anyone knows how to undo it?
thank you
Select all ports and then split them.
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Switch_Ports
DarrenOC
Hi @Juanf574 , find your aggregate under switchports then select it and I believe there’s an option to Undo/split.
Juanf574
thank you that worked pefectly.
Excellent and easy steps
Juanf574
yes, thank you for that.
had replied
