VRRP
mcvosi
VRRP
I currently have two MS250's in a stack, but I am needing to create two port mirrors for analyzing traffic. Since there is a limitation of one mirrored destination per switch stack I am thinking of VRRP. Can the stack ports still be used, or do I need to use an SFP?
GreenMan
Meraki Employee All-Star
You can't use the stacking ports no - you'll need to use a standard link (or two, as a LAG) between the switches.
The SFP+ slots obviously provide the best options for high-capacity between the two - maybe using DAC:    MA-CBL-TA-1M   (3M also available).    Full list here:   https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu...
you could also just use some copper ports and some patch leads, if high capacity (10 Gbps+) between the switches isn't necessary.
Make sure your STP setup, in terms of root bridge, matches your VRRP config.
I take it that, by two port mirrors, you mean two different destination ports for mirrors?
Here you can read the overview about MS warm spare.
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Warm_Spare_(VRRP)_Overview
GreenMan
mcvosi
Yes, two destination port mirrors.
