Issue:
We have an endpoint with a PEAP Ethernet profile connected to port 5 on a Meraki switch. We have also configured the 802.1X access policy on the Meraki switch and applied it to port 5.
When testing the RADIUS server from the switch, it successfully reaches the ISE, and logs are visible in ISE.
The endpoint is sending EAPOL Start and EAPOL packets to the switch, but the switch is not relaying the RADIUS packets to ISE.
Additional Context:
At first I thought it was the windows supplicant issue (as I have read some people had issue with Windows 11). I configured dot1x on a cisco catalyst switch, and I connected the same system to it. It immediately got connected and i can see the log in ISE. Then I ruled out windows as the issue, and norrowed it down to Meraki switch issue. I did packet capture on the port on the meraki switch the system is connected and I can see the endpoint is starting EAPOL and sending EAP packet, the switch is not just relaying it to ISE.
I am having this issue with Meraki MS210 switch and as well as MS 225 switch. Raidus test from the switch to the ISE is visible from ISE logs but I am not see any logs for devices connected to ports that the access policy is applied to. Also, MAB is working on the port, but 802.1x is not working. Is there anything I am missing? This is driving me crazy. Please help out, this is a cry for help!!!
