MS 15.17 bug report - mgmt vlan is displayed incorrectly when changed - never updates
ToryDav
Current Firmware - MS 15.17
Model: MS120-8LP
Severity - None (informational)
I removed VLAN 1 from my network and changed the management vlan to vlan 10. all my equipment uses DHCP for the LAN management IP in my lab, so the change was easy - however I noticed that the MS 120 still displays vlan 1 on the LAN IP.
I can assure you VLAN 1 no longer exists. My uplink does not carry vlan 1
The local status page shows the correct information, just displayed wrong in dashboard.
Switch is healthy and I can ping its address, so there isn't any issue. Just wanted to submit this. Let me know if I should submit this elsewhere.
Thank you.
Tory Davenport
BlakeRichardson
@ToryDav  It would be worth opening a support case just to pass this onto support.
1 Reply 1
BlakeRichardson
