Join a Cisco Catalyst Port channel
kev2five
On my Meraki do I simply configure my desired two uplink ports with native vlan and allowed vlans.
Then select them both and choose Aggregation.
Then control the negotiation etc from my upstream Cisco Catalyst with matching configuration?
Lastly, how to I take two ports out of aggregation on Meraki? Select both ports and ?
@kev2five they are the dedicated stacking ports on the back of the switch.
7 Replies 7
Brash
Yes, you simply select the ports you wish to aggregate and apply.
The Cisco Catalyst side requires matching VLAN config and LACP Active or Passive mode.
Removing ports from aggregation involves selecting the ports and clicking "split" in the Meraki dashboard, and removing the port-channel config from the Cisco switch side.
Note: I would shut down all links in the bundle except for 1 to avoid introducing any potentials of loops.
More information can be found in the following doc - Link Aggregation and Load Balancing - Cisco Meraki
Nikhil2311
Yes if you want more information of Load balancing and link aggregation you can visit below site:
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Link_Aggregation_a...
kev2five
Thanks for the swift reply.
I've unsplit on my test switch, so thats good to know.
I seem to have somehow put two ports on my test switch into Stack mode. How does one unstack these two? I seem to only have edit option>name.
When reviewing switch stack page, it is empty. But on Switch Ports I have two listed as dedicated stack.
GIdenJoe
Only an MS425 can have stack ports on the front.
You can change them back to regular switchports in the switch -> switchports page and just change the mode.
kev2five
Thanks, I have tried that. My only option that is not greyed out once I tick a port, is édit', and this gives me the window to only change the description.
Its a MS225-48LP switch.
