Is it possible for me to connect my internet link first to a switch (MS)
iagoaas
hi guys, Is it possible for me to connect my internet link first to a switch (MS), and then exit with two cables, one for each MX? I have only one internet link (just 1 IP) but I have two MX's at the other end.
Yes, It is. Take a look at this example:
But you need at least 2 IPs, one from each MX. Three if you are considering using virtual IP.
iagoaas
excellent, i am try this, thank very much.😊
iagoaas
I just verified that my (INTERNET) circuit delivers /31 and the meraki MS120 switch does not support it.
FabianSchleef
Your Meraki MS120 switch doesn't need to have any IP parameters configured for your WAN circuit.
You just need to configure a L2 transit VLAN (any unused VLAN-ID) on the interfaces facing the WAN-router and the MX WAN-interfaces.
