good morning, im not sure if this topic was discussed before, if it was I apologize in advance, can anyone explain\show me how to block ipv6 DHCP servers on Meraki MS225 running on MS12.28?
apparently this feature is not available yet on MS switches which is mindboggling, on the cat switches i could set a ipv6 DHCP snooping command to block. at this point it seems the only "fix" for my issue the only way to block that traffic would be to configure an IPv6 ACL on my switches.
Hi @ZeeBoussaid I'm trying to do the same thing in my network. Did you find a solution in the end or just block the traffic with an IPv6 ACL ? Many Thanks
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
