Turning OFF Meraki Switch
Motswahole
Good Day,
I just need clarity on what will happen if a meraki switch is turned off during night time, and turned on the next morning.
Thank you.
Brash
The switch will do nothing when turned off.
When turned on, it will boot into its last saved configuration and will resync with the cloud backend.
5 Replies 5
Brash
KarstenI
Just don't try to control the switch's power with the MT40 that uses the AP connected to the controlled switch ...
Brash
Speaking from experience? 😆😜
KarstenI
Well, it was not an MT40 ... 😉
BlakeRichardson
Not a lot, simply the dashboard will alert that the device is offline and anything connected to the device will go offline.
