IOS XE Firmware Questions - switch.meraki.com / my.meraki.com and redundant power
Bovie2K
First I'm seeing switch.meraki.com / my.meraki.com don't work are you just at a loss if you loose internet and can't change uplink or config settings locally?
Also I'm seeing MS390 and Catalyst-based switches do not support redundant power as an option. I'm assuming if you stay under the power supply needs for a single power supply loosing one will provide redundant power? or will loosing one power supply just kill the entire switch?
@Bovie2K indeed, combined power is the only option and as long as you stay within the requirements of one, the switch will still operate.  This even includes across a stack where one 1100W PSU could power multiple switches as long as the PoE draw isn't too much.
6 Replies 6
The local management page is available via the port on the back. Using the Cisco Meraki Device Local Status Page - Cisco Meraki Documentation
Bovie2K
Thanks seeing this Catalyst switches onboarded for Cloud Monitoring will continue to run IOS firmware, which does not support access to the local status page. However, Catalyst switches operating in Meraki-managed mode will run CS firmware, which does support access to the local status page.
Bovie2K
I was wrong here. Meraki-managed IOS XE has the local status page.
Inderdeep
This is by Default
and you have the option
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Bovie2K
Ya I've got two 1100's on my C9300L's its just odd the Meraki console says they don't support redundant when they do.
