How to add access list in MS120-48
Merakibgp
Hi How to add access list in MS120-48. Anyone can send me a link on this? thank you
jdsilva
Go here:
https://meraki.cisco.com/support/
And then type "MS ACL" in the search bar. The first result should be what you're looking for.
10 Replies 10
jdsilva
Go here:
Thank you!
BTW, on the page, Switch ----> IPV4 ACL.
There i can see several ip addresses under "Dashboard IP address" What does that mean?
jdsilva
@Merakibgp Those are the IP addresses of the Meraki Cloud. If you create rules you want to be sure you don't block access to those specific IP blocks as your devices will be unable to contact the cloud and you cannot manage them.
The MS120 is a layer 2 switch. I'm not sure it supports ACLs.
jdsilva
Oddly enough, @PhilipDAth, they do.
You have two options.
Switch > Configure > ACL
OR
Switch > Configure > Routing & DHCP
The MS120 series will only support the following  "This switch only supports interfaces for DHCP relay and IGMP snooping querier functionalities."
You cannot setup L3 routing ACL on this model of switch.
@BlakeRichardson
Isn't it Switch>IPv4 ACL or is that just a difference in our interfaces?
jdsilva
@Adam Maybe it's a version thing? I have both in my dashboard in different networks...
