The reason behind this is a bit off an odd ball but its a feature available on MR units and other vendors offer this feautre.
What is everyones thoughts on be able to enable dark mode on MS units, you can already blink the LED so the feature is possible. What alerted me to the fact is I havea guest staying and they room they are sleeping in happens to have a MS unit (fanless) in there and I though I would disable to LED's before they went to bed.... it turns out you cant but a nice piece of tape over the front solved my problem
However it got me thinking should this be a permanent feature?
