Max POE+ power available?
StevenJ
The MS250 series has a listed max POE+ budget of 740W, but it can also take a secondary/redundant power supply. Can this second power supply run in combined mode (like some Catalyst series switches) or does it only run in redundant mode? Does the second power supply increase the POE budget and if so up to how much?
Thanks for any help.
DCooper
Meraki Alumni (Retired)
@StevenJJust redundant power, it doesn't add anything to your PoE bank. You may add that as feedback at the bottom right hand corner.
1 Reply 1
DCooper
