Hi Aysha,
Thank you for sending screenshots.
Is your main goal to add VLAN=1213 to the Active VLAN Database?
Please check below.
VLAN profiles is supported on the following platforms and firmware versions:
Platform Family | Model | Minimum Firmware |
| Catalyst C9K-M | C9K-M | CS16+/Cloud Native IOS XE |
Have you enabled VLAN Database feature by navigating to Organization --> Early Access --> VLAN Database Opt-in?
The VLAN Database feature provides a simple way to remove, or prune any VLANs that are not needed from the switch's VLAN database and allows for a single place to configure the entire VLAN range needed in the topology and/or the switches attached to a VLAN Profile. This has historically required additional effort on a switch by switch basis to modify.
The VLAN Database is a function of VLAN profiles, which can be applied to individual or groups of switches. An example would be if you use the same VLANs across many switches in a network, a single VLAN profile can often be used to limit the active VLANs.
This feature is limited to Cloud Managed Catalyst switches only. This feature does NOT effect how MS Classic series switches function.
In conclusion, in your case the default Active VLANs for the Catalyst 9300 are between 1 - 1000.
Therefore, if you would like to use VLAN=1213, you will have to use Prune function.
Example, Active VLANs 1-999, and 1213 --> That way you will remove VLAN=1000 from the VLAN DB.
If you have any further questions, please don't hesitate to contact us 🙂
Note: If a user configures a VLAN on an access port that is NOT in the Active VLAN list, IOS XE will auto instantiate that VLAN. Dashboard will remove/prune that VLAN within and hour for IOS-XE devices but NOT for devices running CS Firmware.
