CISCO MERAKI MS120-24P NOT ABLE TO REGISTER ON CLOUD
KUBWIMANA
Good morning ?
I have a cisco meraki ms120-24p , while I try to add  its serial number in my dashboard's account , I get a message saying that " The following devices are already in use " . I don't know who has added it before me .
I want to get the full configuration settings so that I can be able to initialize the configurations management and install VLANS.
Is it possible to configure it locally with out cloud platform ?  Any good information you can help me pls .
Thanks you .
2 Replies 2
Did you buy second hand?
You must ask the person you bought it from to remove it from the organization.
Important information, there is no point asking Meraki support the most they will provide is the name of the organization the switch is.
BlakeRichardson
Is the device brand new or second hand, if second hand the previous owner hasn't removed it from their organisation and if they ghost you then you have an expensive door stop.
If the device is brand new you will need to contact your account manager.
