Current clients on MS390 (14.33.1) switch is very high
AzureInnocence
Hello there,
I'm noticing that the Current clients count on the Switch overview page is showing a very high count that ranges from 700 to 1500.
There is a Primary MX with a secondary MX  which connects to two MS switches in a stack. There are only 10 MRs.
The client count on the Network-wide -> Monitor -> Clients is normally around just 80+
I am not sure why the Current clients count would be so high.
AzureInnocence
Hello!
Seems updating to MS 15.21.1 has solved this issue now.
2 Replies 2
I'm pretty sure that it will include all client discovered on the network including wireless clients.
Have you checked with Meraki support?
AzureInnocence
Hello!
