C9300L and 802.1x Windows Network Policy Server
Bovie2K
Hello, I've got some new C9300L's but am having a hard time with 802.1x Windows Network Policy Server. It works great with our MS series switches but cannot get it working with the C9300's.
First I figured out it's not using Ethernet as a NAS port type it's using Async (Modem). Second it won't accept PEAP and MS-CHAPv2. It will only accept PAP, SNAP which is no encryption. That will get the NPS logs to show an accept on the request but Meraki still shows a deny when testing radius.
Does anyone have the new C9300's 802.1x working with NPS? Note I have the same experiencing the same issue with both MS firmware and the new IOS XE public beta.
Bovie2K
Support resolved the issue for me. When diagnosing the issue with the CS firmware we added a second access policy for testing. Turns out there is a bug with the IOS XE firmware where if you have 2 access polices only one of them work. We removed the second policy and it works. This still doesn't answer why I had issues with the CS firmware but with the IOS XE firmware I'm fixed.
8 Replies 8
Bovie2K
More information. Working with Meraki support the IOS XE firmware doesn't even seem to be sending radius request. Super odd. Same question anyone running C9300's with NPS?
Inderdeep
Maybe it will help you.
 https://documentation.meraki.com/MS/Access_Control/MS_Switch_Access_Policies_(802.1X)#RADIUS_Caching...
I hope they fix up the NAS port type.  Tat is going to break a lot of things.  I would call this a bug.
I assume you are using an up to date firmware?
Bovie2K
yes running latest IOS XE firmware now and its not even sending a radius request anymore. They escalated my case. Will keep updated here.
Mtravaglia
Hi Bovie2K,
Did you get this sorted at the end? I am facing the same issue.
Bovie2K
nope but I'm working with a good tech in support. He has it narrowed down to one of the daemon's marking the radius server dead when it's not and the switch never sends the radius request to the radius server. So he is working with engineering thinking it's a bug. 20/20 hindsight I shouldn't have done IOS XE should have stayed CS but I had issues with CS NAS PORT Type so I tried the upgrade. Will report back when I know more.
Bovie2K
