Cisco Switch Cat 9300 with meraki Lic cannot aggregate 2, or 3 10G port in 10 G Module
AhmedHamad-SM
Just browsing
Cisco Switch Cat 9300 with meraki Lic cannot aggregate 2, or 3 10G port to make it Port Change with 9K switch,
I try normal ports it works, but when I do aggregate with 10G Module its always failed with Error, Meraki Support cannot resolve this issue
2 Replies 2
@AhmedHamad-SM what software versions are you running on both switches?  What switch models are they?
What transceivers or DACs are you using?
Can you please provide more details? Can you share a screenshot of the error you are receiving?
