Hi
I cannot seem to find a way to block a MAC address from connecting to MS250-24P switch. is this possible without creating ACLs and Radius servers?
Any input would be appreciated as new to meraki.
many thanks
Solved! Go to solution.
Basically the options you have are these,but its more like telling who is allowed:
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Switch_Ports#Port_configuration
If you know the IP address the client will get (perhaps via a fixed DHCP reservation), you could create an ACL. You only need two entries - a deny for that IP address and the a permit any.
https://documentation.meraki.com/MS/Other_Topics/Switch_ACL_Operation
Not sure how well it would work but in theory you could create a group policy that blocks all traffic, then manually add the client with the Mac address and assign it the group policy.
I think that is "by client" and that is not supported on switches
